450 JD steering clutch shaft removal
scooty
Post by scooty » Fri May 08, 2015 7:49 am
Hey guys need help removing steering clutch and brake shaft .I Have removed pinion shaft to bull gear. But can not pull next shaft out, it has a 3/8-16 thread in end of shaft. Pulled on it with puller but did not move. Are their any ring locks on it I have not seen or does it just pull straight out. This is a straight John deere 450 crawler.
Thanks for any help. Scooty
Post by jtrichard » Fri May 08, 2015 7:31 pm
Look here page 5 http://www.jdcrawlers.com/messageboard/ ... c&start=60 if you are pulling both clutches (you may have to pull both) then you can use a brass rod or soft galvanized water pipe 3/4 or 1" from the other side to help drive it out that what Dennis (crawler123) had to do on his
DrLoch
Post by DrLoch » Sat May 09, 2015 5:17 am
Good find jt, Really needs to be a sticky area where some of these important repetitive posts can be placed.
450C Track Loader
291457T
scooty
Post by scooty » Sat May 09, 2015 5:32 pm
jtrichard wrote:Look here page 5 http://www.jdcrawlers.com/messageboard/ ... c&start=60 if you are pulling both clutches (you may have to pull both) then you can use a brass rod or soft galvanized water pipe 3/4 or 1" from the other side to help drive it out that what Dennis (crawler123) had to do on his
Thanks for the information
Scooty
markmc60
Re: 450 JD steering clutch shaft removal
Post by markmc60 » Mon May 11, 2015 6:28 am
scooty wrote:450 JD steering clutch shaft removal
there are no locking pins, clips or any thing else, I used a slide hammer. support the clutch assembly and get after it, be aware that there is a spacer on the end of that shaft.
450 dozer
markmc60
pic of the shafts
Post by markmc60 » Mon May 11, 2015 7:07 am
shafts, pulled and a pic of the spacer on the end of the inner shaft
450 dozer
Users browsing this forum: No registered users and 38 guests
