1010C hydraulic cylinder
gregjo1948
Post by gregjo1948 » Mon Apr 27, 2015 4:34 am
Is there some place that I can get a 1010C blade lift cylinder repair kit? Thanks, gregjo1948
Mikeym70
Post by Mikeym70 » Mon Apr 27, 2015 7:52 pm
I've found that pulling the cylinder apart and taking the tube/piston to my local hydraulic shop to have the seals measured and supplied is the best option. I just ordered seals in this fashion for the cylinders on an old John Deere skid steer, all seals/gaskets were $24 per cylinder. John Deere was more than 3x that price to supply a kit.
If you can do the work yourself and have the machine down a day or two it's a nice little cost savings.
1010 gas crawler 6 way blade. New to me 3/2015.
gregjo1948
Post by gregjo1948 » Tue Apr 28, 2015 4:49 am
Mikeym70 wrote:I've found that pulling the cylinder apart and taking the tube/piston to my local hydraulic shop to have the seals measured and supplied is the best option. I just ordered seals in this fashion for the cylinders on an old John Deere skid steer, all seals/gaskets were $24 per cylinder. John Deere was more than 3x that price to supply a kit.
Thanks... I can't find any numbers on it while it;s mounted so, I'll pull it off and inspect it closer. Lots of places on-line to purchase if I find the numbers. If no numbers to be found, I'll do as you have suggested. I have a hydraulic shop about 30 miles away. They do good work but get big bucks. gregjo1948
gregjo1948
Post by gregjo1948 » Sat May 09, 2015 4:19 pm
Just to update; Took it to local hydraulic shop. They found no repair kit either so, they ordered individual pieces. Cost me $62.00 and it works great and dry now. gregjo1948
Mikeym70
Post by Mikeym70 » Mon May 11, 2015 6:02 pm
Glad to hear it worked out for you!
Users browsing this forum: No registered users and 311 guests
