420C axel shaft shims
My labor of love is restoring Dad's crawler. Retired now and in a little over my head on this project, but have manuals and parts from Lavoy . I put all new parts in right side final which showed signs of water damage at one time. Now after assembling axle shaft it needs almost 1/4 inch of shims. It didn't appear damaged or worn and I think it's assembled correctly. Is it ok to go ahead and shim that much ?
Found Dad's 420C
No, should never take that much, do some more checking first. Make sure you have the washer behind the inside bearing, spacer badly worn, etc.
Users browsing this forum: No registered users and 541 guests
