Steering clutch bung removal
phried
Post by phried » Sun Apr 19, 2015 11:13 pm
I just got the machine and I'm pretty mechanically savvy but I've never worked with drum plugs aka bung plugs before. What is the best tool(s) to use for removing and re-installing these?
A full wrench like this?
Is there a socket that is appropriate?
I saw a youtube hack video of using 2 large screwdrivers but that sound annoying if this is needed more than a couple of times.
1960 440ICD w/ 831 loader + ripper Ser # 455747
Post by Stan Disbrow » Mon Apr 20, 2015 5:12 am
There is a bung wrench. About $40 from the usual sources of Cheap Tools (Northern, Harbor Freight). I made one starting with an old pair of channel lock pliers and ground the back sides of the jaw tips down a little so they fit the bung nicely. Just need to pull the handles open when using on bungs. They still work as pliers as well as a crawler bung wrench.
phried
Post by phried » Mon Apr 20, 2015 10:18 pm
I ordered the Amazon one since it looks similar to the Northern Tool one but at 80% lower cost.
Paul J
Post by Paul J » Wed Apr 22, 2015 7:23 am
I used a common pair of pliers on mine. Stick the ends of the handles in position and a large screwdriver thru the jaws for twist leverage. Couple of blood blisters later, and it's loose.
It's a ten minute job to make a decent wrench for barrel bungs, but I've never taken the ten minutes to do it. Maybe today. . .
420C, 5 roller, 62 blade
Post by Paul Buhler » Thu Apr 23, 2015 4:03 pm
Hi: The pliers handles and screwdriver method worked for me to get the steering bungs to open (or use a cold chisel/drift and hammer), then a bit of Anti-Seize on the threads keeps them working fine. New O-rings and finger tight keeps out the rain, which is all that's needed. Good luck. I borrowed a barrel bung wrench from a friend when I needed to get my winch bung open, but didn't want to invest in one. Paul
Paul J
Post by Paul J » Thu Apr 23, 2015 8:06 pm
A photo posting test.
Bung wrench made from a cracked socket and a 1 7/8" long piece of 1/4" thick scrap.
phried
Post by phried » Mon Apr 27, 2015 11:14 pm
Ha! That is awesome!
