....is they deteriorate so very gradually.
Which, I was just reminded of over the past two weeks. The solution, of course, is to stick in a brand new one. Preferably, an actual JD Strongbox brand one. If your local dealer parts guys actually know what a 6v battery still is.
The background is I last put new ones in my 420c and M (standard, wheel tractor) ten years ago. I keep them maintained at least on a yearly basis, usually working them over in the Spring. By that, I mean pulling them out and watering them, cleaning or renewing all the connections, and giving them at least an overnight charge with a small 2 amp charger.
This, because in Winter here in NC it is too wet to doze anything and we rarely get enough snow which would require a dozer to plow. The M is used with a fertilizer spreader and a set of disc hillers and a cultivator rig. Hardly things used in Winter.
My main machine I would use in Winter is my 2008 5103 with loader and back blade. But, that isn't 6 volts, so it really doesn't fit this topic. I mention it because it helps illustrate why the two older machines sit unused for three months.
But, come Spring there are plenty of jobs for both antique machines to do. So, I wish to service them both so I can simply jump on and go. The usual oil and lube jobs must be done, and service the electrical systems as well. Because with only 6 volts, there are no electrons we can lose and get them to start properly.
Now, to the insidious part. A 12 volt battery tends to work OK, and then one day just give up the ghost. As in it fired up yesterday, and won't even turn over today. A 6 volt battery, however, slowly loses the important Cold Cranking Amps. But, it will still turn over the engine. Ever more slowly. This is the very definition of the word insidious!
Electrically, what happens is a 6 volt battery is nominally 6.5-6.3 volts with no load. When cranking one of our vertical 2 cyl engines it drops a volt or a tad more to 5.4-5.2 volts. This leaves enough for the coil to spark well. With decent compression (I know this varies quite a bit from one to the other), it ought to pop off in a couple revs of the crank.
But, an older battery, while still able to crank over, will drop below 4 volts. This is no longer enough to fire the plugs properly. So, no fire. Or, worse, it fires the plug weakly, and the fuel charge fires just before TDC and the thing tries to start backwards.
This is what I was getting last fall on both machines. Having to crank several revs for only a backwards fire. I knew the batteries were insidiously about done. Now, I could fire either up using my (also antique) 6/8/12 volt charger with a Start Boost for 6 volt. This is a big shop charger from back in The Day. A leftover from when my family had dealerships.
But, I knew I needed to replace both batteries come Spring. Last week, I put a new one in the 420c. One such battery is all the local JD dealer stocks. I had to order the second one, so that came in this week.
Why spend extra for a JD brand battery? They have their own battery plant. Their Group One has 200 more CCAs than the next best one, Interstate. Which, BTW, is better than any other brand of 6v G1 out there (various auto parts stores or even Batteries Plus).
So, now both machines pop off on the first full rev, and I ought to be good for another 10 years.
I brought this up because of a couple other recent electrical problem threads and the thought that lots of us are likely firing up our Old Iron after a long Winter's Nap.
