450 C threw a rod
vthartford
450 C threw a rod
Post by vthartford » Sun Dec 17, 2006 1:55 pm
Today, my 450 C threw a rod and punch a hole in the crankcase. After inframe rebuilting approx 30 hrs ago, I don't know what happened. Looks like the rod bolts broke from what I can see.
Anyways, anyone know of a good source for a rebuilt 4219 motor. What should I expect to pay? I really do not want to build another one.
Thanks, Bill
JD430C
Post by JD430C » Sun Dec 17, 2006 8:40 pm
hi bill, did u reuse your rod bolts? i just took the 219 in one of my 450c's apart. a friend was over helping that has rebuilt many of them, and told me never use those rod bolts over again. as for a rebuilt motor, i am guessing 2 to 3k, probably less if u find a good used one.
andrew
vthartford
Post by vthartford » Mon Dec 18, 2006 5:45 am
No, I used new rod bolts. MY only guess is one worked loose. I hope I can find a used runner or a cheaper rebuilt. 3K is a little steep, I hope I can do better than that.
BIll
JD430C
Post by JD430C » Mon Dec 18, 2006 1:10 pm
bill, u lookin for a 219 or a 219 with the turbo? i have a friend with a jd 410 backhoe, motor runs good, but the transmission case is cracked. i believe its a 219, i can ask if he wants to sell it if u are interested. i have a 219 block, just striped it for the crank, could sell u that if interested.
andrew
vthartford
Post by vthartford » Tue Dec 19, 2006 4:57 pm
Andew, I would be very interested. sent you an email but if you did not get it, email me at vthartford at windstream.net or call me at 904-742-0251.
Thanks,
Bill
sandman2234
Post by sandman2234 » Sat Jan 06, 2007 10:46 am
I wonder if the old motor can be saved? Although I have never used them, there is a Block and Head welder on Lenox Avenue that might give the old engine a chance. While it is down, and your looking, it might not hurt to give them or their competition a call. In todays throw away society, that is a dying business, but those guys have been there awhile (or at least the building has). Someone that has the right experience can give you a lot better idea on saving the old motor, but I have seen several motors with plated sidewalls where rods decided to find some fresh air.
Good luck with it,
David from jax
Have gun, will travel
digitup
Post by digitup » Sun Jan 07, 2007 12:05 pm
Rebuild if there is no crank damage ma bey .The biggest problem is finding all the block pieces .That backhoe engine will fit right in.Digitup.
Users browsing this forum: Google Adsense [Bot] and 48 guests
