Introduction and JD 350 brake / clutch
Parts coming!
Welp I called up Lavoy today. Parts are on the way. I'm just gonna do it all. Clutches, steels, brake...... everything. No need to monkey around and do it twice. Will post back when project is moving forward.
A person who never made a mistake never tried anything new.
1966 JD350 Straight
1966 JD350 Straight
I turned it into a clickable link. It is too early in the morning for me to troubleshoot it.
http://i.imgur.com/jxw5IHm.jpg
Pilot bearing problem
Most of the parts have come in. I still have to check the post office to see if the pressure plate came in yet. I am having some issues with the pilot bearing. I took all the clutch plate and disks out, with a hammer and punch as they were all rusted together. Got to the back gear where the pilot bearing rides and found the pilot trashed. I was able to pull the inner race, the ball bearings( which are now flat on one side) and half... yes half of the outer race out. The outer race is broken about half way in around the whole circumference. So it is basically split in the middle. It appears that the race cocked sideways in the there and mushroomed the metal to where the part that is left is hanging up on the mushroom. Also on the input shaft where the inner part of the pilot bearing rides is chewed up. Hope that makes sense I'll try to get my photo account sorted out so you all can see what I am talking about.
So in short the input shaft is chewed up where the pilot bearing rides and the gear /shaft that the pilot bearing is pressed into is chewed up. I am wondering if anyone else has ran into this and what was the fix. I am thinking about machining it all down if I can find an oversized bearing or using a sleeve.
1966 JD350 Straight
1966 JD350 Straight
Finally got some time
Welp I finally was bale to get freed up enough to work on the crawler today.
I made a mistake and messed up the brake band. I had 6 chunks of all thread with nuts and a small ruler. We stabbed the shaft in the clutch pack first so as to make sure it seated in the pilot correctly. Then started drawing it down with the nuts on the all thread while supported from the bottom with a big floor jack. We were real careful to make sure the brake got over the bevel on the drum before tightening down the nuts. I kept everything lined up within a tenth of an inch the whole time. Everything got down to about 1/4 of an inch within the gearbox touching the main box and it stopped. I gave her a couple good taps( probably where I went really wrong) with a big hammer. I was thinking it was hanging up on an alignment pin. No go. So got to looking from the top and noticed that the friction material is was peeling off of the band. I am not entirely sure where I went wrong. We had only about 4 or 5 threads on the nut for the band. Everything was straight. I am thinking that one of the linkages from the top got hung up and was holding the brake slightly closed.I have all the stuff up top tore apart too. Any suggestions?
1966 JD350 Straight
1966 JD350 Straight
throwout bearing not returing
Also another thing that I was ignoring that I am think I might try to deal with is the fact that the return spring for the throwout bearing does not have enough force to overcome the rusty shaft upon which the throwout bearing rides ( the little forks), I started to try to drive it up and out but am thinking I might be opening a bigger can of worms that it is really worth. I mean what would be the harm in just making sure to push the steer handle all the way forward when not steering? Any thoughts on this? It retracts with a little bit up help and am thinking that maybe the clutch fingers will help get it past the point where it seems the stiffest. What peoples experience with these? Maybe I should get a new spring? The old one seems decent but perhaps a new spring would help. The fork part ( that holds the throwout bearing) is rusted pretty hard to the vertical shaft that has a linkage at the top.
Sorry for no pictures. I have tried to set up an imgur account but it seems that I am the only one who can view my pictures.
1966 JD350 Straight
1966 JD350 Straight
Users browsing this forum: No registered users and 224 guests
