40C idle pulsing after warm up
- BradE
My "new" 40C idles a lot like my last one. After it warms up, the idle pulses, probably from 1000 down to 500 and back up; engine runs fine otherwise. I just had the carburetor rebuilt before I started using it this winter, but was doing this before. Is this common? Where should I start?
JD 40C 4 roll 1955, snow tracks and sprockets from a 350
No slam on your carb guy, but what exactly did he do as far as rebuilt. I have "rebuilt" a few rebuilt carbs over the years, and most people just soak them, put in gaskets and call it good. My guess is you have a plugged idle circuit, that is what I have found when I get the symptoms you describe.
- BradE
I bought a kit with new gaskets, orifices. My carb guy did say that none of the jets he replaced had gaskets, so he used the gaskets that came with the kit.Lavoy wrote:No slam on your carb guy, but what exactly did he do as far as rebuilt. I have "rebuilt" a few rebuilt carbs over the years, and most people just soak them, put in gaskets and call it good. My guess is you have a plugged idle circuit, that is what I have found when I get the symptoms you describe.
I'll take a look at it for a plugged idle circuit when winter logging is done and the ground is too soft to use it much. (Those snow cleats make a mess of the lawn!)
Okay, I am a little stumped, none of the kits available today that I have found have jets with them, they need to be ordered individually.
Howard Yoder
Users browsing this forum: No registered users and 20 guests
