BearRocks
Post
by BearRocks » Thu Mar 26, 2015 2:14 pm
Let me start by saying that I'm a Dozer virgin this being my first. It's a JD 1010 that I just bought several months ago and have run it very little. Today after pushing out some barberry, multiflora rose, and small trees (Wrist sized) I was headed in off the Back40 when the right track seemed to catch and it stalled out. I got off not knowing what to look for but noticed this.
right side.
left side.
This looks bad to me. What did I break
.It supposedly has a new undercarriage with few hours on it.
Rick
- Site Admin
Post
by Lavoy » Thu Mar 26, 2015 4:52 pm
Looks like bad final drive bearings to me, although could be broken axle. Either way, only way to check is pull the final drive, and don't run the crawler unless you want to spend lots more money.
By the way, can't see the rest of undercarriage, but sprockets are very worn, definitely not new..
Owner and moderator
www.jdcrawlers.com
wizner85
Post
by wizner85 » Thu Mar 26, 2015 4:53 pm
Is the casting broke? Looks like bearing went out and wiped out internals to final drive. I've got parts for a 1010 located in Danville pa if you need any.
Cleanup the final and see if you can find the issue. Then send more pics.
440 ICD 64 blade & 8a gear attic winch
440 ICD 831 loader with scarifier and weights
420 62 blade 3pt
Looking for 24 scarifier and 440 log arch
BearRocks
Post
by BearRocks » Fri Mar 27, 2015 7:04 am
Thanks guys. Now the search is on for a dozer mechanic. Will let you know what I find out.
cdunn
Post
by cdunn » Fri Mar 27, 2015 12:52 pm
Hey man, your the mechanic, go for it.
57 420c 86 Ford 4600
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
