350C power reverser
jeepglenn
350C power reverser
Post by jeepglenn » Thu Mar 05, 2015 11:20 pm
Hello, does anyone know a source for a complete power reverser for a 350C. Mine is weak and maybe the solution is to replace a complete unit rather than rebuild. Thanks.
JD 450C
JD 350C
IH 584
Ford 1300
MM 707
MF 95
pondhogvt
350C
Post by pondhogvt » Fri Mar 06, 2015 5:59 am
Dear sir I have a complete reverser if needed.. Also there should be a tag by the starter. a little aluminum tag.. the first numbers should identify your motor.. should say 3-164 or 3-179 etc.
the 350c has a different reverser than a standard 350 or 350B model,, I would also have the major components if you should decide to rebuild it yourself,, good luck.. Mark 8002-279-1888
JWB Contracting
Reverser Rebuild
Post by JWB Contracting » Mon Mar 09, 2015 9:04 pm
Sorry about the high price here in west central Alberta but getting a good 350C case is difficult. The one I have available is in a working machine., I paid good money for this machine at auction in case w needed parts for our working tractors. I'm also working a deal for a widepad 350C with a cracked case.
You have to pull your machine down anyways. You might find yours isn't that bad and just needs a gear, bearings and seals.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Users browsing this forum: No registered users and 39 guests
