Hello, I have a 1980 350C and the isolator plate has broken springs twice in 700 hrs. Does anyone have any suggestions as to what would be causing these failures? I have the engine out now and it appears that one of the anchor bolts came loose and stripped the rest. The plate looks OK so I should be able to get buy with just new springs and bolts.
The part numbers:
Isolator pn AT29086
Spring pn T29675
Retainer pn T55320
Any advise will help, thanks.
350C engine flywheel isolator failure
JD 450C
JD 350C
IH 584
Ford 1300
MM 707
MF 95
JD 350C
IH 584
Ford 1300
MM 707
MF 95
All of those parts are Deere only. I am working on a kit to convert to later style isolator which will eliminate the problem, but that is the best I can tell you.
I don't have direct experience with the spring isolators, but the others that have spoken on here about them say it is critical that the springs and tabs are installed with a threadlocker sealant or they can come loose and cause havoc similar to what you described.
350C isolator
As Tigerhaze says installation details are critical. I think Jdemaris gave the comprehensive list of installation procedures on yesterdays tractors. If you are a little bit adventurous there was a fairly recent post on 350C isolators here that detailed using a 100+HP rated clutch disc bolted onto the flywheel as an alternate to the 350C isolator.
Can you post a picture of how you had it assembled, or just describe it. Assembly is very important, cleaning/prepping the threads and Loctite them along with proper spring installation and bolt torque pays off. if you have a minute look at the pics I posted a couple threads down. I have my stock flywheel, springs, isolator and anchors assembled under the bench, if you need I can post a picture of how it should be assembled if that will help you.
