2010 diesel starter
vailvalley59
2010 diesel starter
Post by vailvalley59 » Sat Jan 10, 2015 11:11 am
I took the starter off and took it apart again--found the bolt that holds the arm that activates the bendix drive was missing its nut and the bolt was falling out--I took the unit apart to dress up the end of the gear and can't remember how this arm goes back in. Any help or web sites that might show me? All other parts seem good--I have no history on this unit but it would seem to me that the starter has been overhauled sometime not so long ago. thanks
2010 diesel loader, IH 886, Cat 1947 D4 dozer, IH 966, Ford 7000, IH 2500, IH 706 and other toys
jksstarter
Post by jksstarter » Sat Jan 10, 2015 5:24 pm
If you're are referring to the shift lever(forked lever with plunger attached)it will go in either way with the fork in the back part of the drive assm and the shift pin(bolt) replaced. Hope this helps Jason
vailvalley59
Post by vailvalley59 » Sat Jan 10, 2015 6:30 pm
Thanks--but there is a difference in the two sides of the lever in this case--I was not quick enough to check when I took it apart. I will try the unit with a jumper cable and see if the gear goes out far enough.
jksstarter
Post by jksstarter » Sat Jan 10, 2015 7:17 pm
The flat side of the shift lever faces away from the solenoid if that make sense to you.(Delco used a few diiferent styles of shift levers). Using your jumper cable, connect ground cable to body of starter and connect B+ to just the switch terminal and it will energize just the solenoid without power up the motor. The drive should come out to within app. a 1/16 in. from the stop collar. Hope this helps Jason
PS Don't energize solenoid terminal for more than a few seconds as it will get very hot quickly.
vailvalley59
Post by vailvalley59 » Sat Jan 10, 2015 8:59 pm
Thank you--will try tomorrow.
vtjoe
your starter
Post by vtjoe » Sun Jan 11, 2015 8:03 am
at this point in my life, I always take a photo or two of a project before disassembly................ to help the mind
1957 420C four roll since 1982
vailvalley59
Post by vailvalley59 » Wed Jan 14, 2015 8:37 pm
Installed the repaired starter on the 2010 yesterday (a warm 23 degrees here). Today (high of 28 degrees) I blead the fuel system and fired her up--no problems. Everything seems to work as it should--the primer pump works wonders in the cold weather. I seem to have a small leak in the radiator as I saw some antifreeze on the ground--this is new--always something. Also a question:
the pins in the loader tilt arms that have a hex opening on the end--how do they come out? Use an impact?? What keeps them from turning?? thanks
Users browsing this forum: No registered users and 20 guests
