Rocker arm studs
username
Rocker arm studs
Post by username » Sat Jan 03, 2015 4:00 pm
I have a 165 G engine that I am trying to get back together after about 6 months.I have 4 rocker arm shaft studs,actually 3 studs and one bolt.2 long studs and one short one machined on the end.My book says to use the short machined one on the rear for oil clearance but the valve cover looks like it needs the 2 long ones on the ends.What am I doing wrong?My book is for a 1010 so possibly they are different than the 165 G?
Post by jtrichard » Sat Jan 03, 2015 5:23 pm
take an air hose and blow in the holes only one has and oil passage in it...... on the diesel it is the rear one dont know on gas
Steelburner
Post by Steelburner » Mon Jan 05, 2015 8:32 pm
The rear one is a tall one for the rocker cover and has the cut-out for the oil passage on a late model 1010 gasoline (115 CID). Make sure to line up the cut-out with the oil passage. There is a plug on the passenger-rear side of the head that plugs the hole drilled for the oil passage. Check out my incomplete thread on 1010 gas engine overhaul for some pictures. My engine has 2 studs (forward and aft) and 2 bolts. Is it possible the short stud was a bolt once upon a time?
Late model 1010 crawler loader
username
Post by username » Tue Jan 06, 2015 9:09 am
I did check with air pressure and the rear port is the oiler.
My rear machined stud is 5 1/8 and the other two studs are 5 3/4 and there is no evidence that they have been tampered with.
I can wait till I get my other engine apart and use those studs.
Users browsing this forum: Google Adsense [Bot] and 339 guests
