Hello
My clutch and brake pedals are frozen together. I have a pretty good idea that I am not the first to have this happen. I am sure that there are a lot of good ideas out there to get them working independently again.
I would like to work on this tomorrow. I have oxy/acet if needed.
Thanks for your help
clutch / brake pedals on 420C
- DukeofDeere
A little heat, then apply some Magic Elixir. Which is 50/50 Acetone and ATF mixed. Works wonders.
The warm (not hot) metal allows the Elixir to soak right in there. The acetone thins the oil so it flows well, and also loosens up rust and gunk in there.
- Paul Buhler
brake, clutch rod
When you go back together with it install a grease fitting or oil hole so it never happens again.
Users browsing this forum: Google Adsense [Bot] and 210 guests
