Fuel Gauge on a 1010
CSW
Post by CSW » Tue Nov 18, 2014 6:46 am
I ordered the aftermarket gauges on ebay that are from India. All seem to work ok but Im having trouble with the fuel gauge. Im guessing that the tank sender needs to match the new gauge am I correct? has anyone ordered these off ebaybefore? If so, do you know the name of the specific manufacturer and If they sell tank sensors?
Post by jtrichard » Tue Nov 18, 2014 10:11 am
Have you pulled the sender and checked the float and the ohms to see if it is working ? or do you even have one?
Post by Stan Disbrow » Tue Nov 18, 2014 1:54 pm
Yeah. The ohms of the variable resistor in the sender does have to match up with the coil resistance in the gauge to be accurate.
Resistance is Futile (probably). Usually offshore gauges don't get it right.
Of course, my 420 has a gauge which always works. A stick! ;)
CSW
Post by CSW » Thu Nov 20, 2014 6:25 am
I pulled the sender, Im getting a reading at the sender but its rusted. nasty and not functioning. Im ordering a new one. Thanks!
