350 engine removel
username
350 engine removel
Post by username » Sat Nov 08, 2014 7:27 pm
Friend just picked up a 350 loader and it needs engine work.He says the book says you need to remove the loader to remove the engine,is there any way around that or is that what needs to be done?
Post by jtrichard » Sat Nov 08, 2014 8:32 pm
YES it can be done without taking the loader off .....here is a 2010 i cant find pics of a 350 but the basics are the same http://www.jdcrawlers.com/messageboard/ ... ve&start=0
splam
No do not need to pull the loader.
Post by splam » Sat Nov 08, 2014 9:17 pm
I just got done rebuilding a diesel 350 and you do not need to pull the loader, I did remove the bucket to make it much easier to remove the engine. Once you have the bucket off, pull the front cowl which is very heavy like everything else on the crawler. Remove the hydraulic pump and radiator. Once you unhook everything to the engine you will need to remove the four bolts that attach the engine to the bell housing. Two of them you remove from the drivers side of the bell housing and the other two you will need about three feet of socket extensions can reach them from the front.
Good luck.
username
Post by username » Sun Nov 09, 2014 5:00 pm
Thanks for the info!
Users browsing this forum: No registered users and 181 guests
