Clutch parts
SEAL
Clutch parts
Post by SEAL » Thu Oct 30, 2014 7:54 am
Lavoy:
I have a 450 crawler loader. Serial # 5E3M012289. I am going to do the clutches and brakes this winter. The parts I know I am going to need are the 14 steels, the 16 friction disks, and the 2 throw out bearings. The 2 pressure plates will be a decision made after I get it torn down. I will rebuild my brake bands myself since I got the procedure and parts list here on this site. Are the springs for the clutch pressure plate available if they are needed verses a rebuilt or new assembly?
I want to thank you for the great site that you run here as it has been very helpful to me and others. If you can give me price and availability on these parts so that I can know exactly how much I need to save up between now and the rebuild I would appreciate it. If you prefer to conduct our business in some other way than on this site please advise me of that procedure.
Steve
Post by Lavoy » Thu Oct 30, 2014 10:12 am
No pressure plate parts are available, sorry. Let me know when you get to that point, I will check on new and rebuilt.
Fibers and steels are no problem.
SEAL
Post by SEAL » Thu Oct 30, 2014 10:41 am
Thanks for the rapid reply. I will be in touch.
Any day you wake up breathing is a good day and the only easy day is yesterday.
ktheaker
brake band rebuild
Post by ktheaker » Thu Oct 30, 2014 10:59 am
could you forward the post author or the post itself , i did search it and could not locate thanks
kt
SEAL
Post by SEAL » Thu Oct 30, 2014 12:51 pm
ktheaker
There are pictures so this may take time to load. It is by RedDirt.
http://www.jdcrawlers.com/messageboard/ ... 7&start=15
ktheaker
brake reline
Post by ktheaker » Thu Oct 30, 2014 2:21 pm
thanks recieved , is lavoy the supplier of the brake lining ?
kt
Post by Lavoy » Thu Oct 30, 2014 3:36 pm
No, I only have new and some relined brakes.
SEAL
Post by SEAL » Fri Oct 31, 2014 6:34 am
kt
Go to the last post on the second page for the supplier and part numbers. I do not know if the 2010 brake lining is the same as the 450 but I would assume someone on this site could answer that question for us.
Steve
SEAL
Parts
Post by SEAL » Thu Feb 12, 2015 10:14 am
I am finally ready for parts. I need 14 steels, 16 fiber disks, and 2 throwout bearings. My pressure plates are OK and meet specs so I will reuse them.
Post by Lavoy » Thu Feb 12, 2015 4:24 pm
Send me an e-mail at postmaster@jdcrawlers.com with name and address, and I will get an order written up.
Thanks,
Users browsing this forum: No registered users and 426 guests
