Rock Guards Grade 8 Carriage Bolts
Goober
Post by Goober » Wed Oct 15, 2014 12:33 pm
Been shopping around to get some replacement carriage bolts for the rock guards on my 450C. No one that I have found makes Grade 5 or Grade 8 carriage bolts in the 5/8x9" size that we need, so I got some quotes on custom. In sufficient volume the cost for Grade 8 would be in the $12/each range + shipping, cost for Grade 5 would be $10 + shipping. Anybody on the board interested and willing to commit to purchase some of these if I do order a run? These are black oxide BTW, other finishes were too pricey to make it even close to worthwhile.
JDParts specs a cap screw for this location now, but that's horribly frustrating to install as I've discovered, and I can imagine the heads get mangled pretty quick during operation.
-Niall
lurch85
Post by lurch85 » Wed Oct 15, 2014 7:51 pm
John Deere 420C, John Deere 350 straight with Gafner loader, John Deere 4020
lurch85
Post by lurch85 » Wed Oct 15, 2014 7:52 pm
9.60 a piece... also trying to find some grade 8 for ya....
they have grade "A" also.. haven't figure out what that means yet (still researching)...
lurch85
Post by lurch85 » Wed Oct 15, 2014 7:56 pm
Post by Lavoy » Thu Oct 16, 2014 7:52 am
Should be readily available from Deere.
Goober
Post by Goober » Fri Oct 17, 2014 1:41 pm
Thanks Lurch - don't know why my searches at the very same fastener stores didn't turn up the options you found, good on you.
Deere only sells a replacement part which is a grade 8 cap screw, not a carriage bolt, requiring two people to effectively re-install it.
lurch85
Post by lurch85 » Fri Oct 17, 2014 8:17 pm
Glad to be of service...
Post by Lavoy » Sat Oct 18, 2014 10:29 am
That's odd, I have bought many rockguard bolts from Deere for the older crawlers. Using the original number, never had a standard bolt subbed in. I can check length on some of the ones I have, they are in the 9" range and give you the deere part number if you want.
Users browsing this forum: Google [Bot] and 215 guests
