percheron
Post
by percheron » Thu Sep 11, 2014 10:37 am
I have Broken 450 B bell housing bolts ? one seems to be stripped out nad hte other is sheared off , the other side is fine . Is the common or just an Isolated instance ?
ja600
Post
by ja600 » Sat Sep 13, 2014 9:28 pm
Fairly common problem on the 450s. The side rail is probably broken also. There are several posts on here discussing it and how to repair the clutch housing. Don't panic and just fix it.
Machinist by trade, farmer by blood.
percheron
Post
by percheron » Sun Sep 14, 2014 8:12 am
I have taken a good long look at the problem one hole is stripped out and the other has the rest of the broken bolt I am going to try and tap the striped hole out to a bigger bolt and try and extract the broken portion with an easy out ! We'll see how easy that will be , all done with an extension to keep from having to disassemble the loader .
ja600
Post
by ja600 » Sun Sep 14, 2014 6:33 pm
Sounds like a plan. You might try left hand drill bits instead of an easy out though.
jsal
Post
by jsal » Mon Sep 15, 2014 4:38 am
Heli coil's work good in those situations used them on my 350 reverser worked good.
JIM
ja600
Post
by ja600 » Mon Sep 15, 2014 9:25 am
Another thing you need to check is what I call the motor mount. I believe JD calls them a bell housing spacer. It's on the inside of the frame rail between the rail and the bell housing. Hopefully it isn't broken but if it is you will have to replace it. They are getting hard to find. I had a set made at a machine shop.
percheron
Post
by percheron » Wed Sep 17, 2014 7:03 am
Ok thank you !
Users browsing this forum: No registered users and 210 guests
