450B STEERING CLUTCH / METALLIC VS FIBER PLATES
FL450B
Post by FL450B » Tue Aug 05, 2014 2:51 pm
JUST TORE DOWN MY 450B FOR STEERING CLUTCH REPLACEMENT LOOK FOR PRO AND CON ON METALLIC PLATES VS FIBER PLATES HAVE LOT OF PHOTOS THAT I WILL UP LOAD TO SHOW RIPPING IT DOWN AFTER I FOUND THE MASTER PIN AND REMOVED IT NO BIG ISSUES TEAR IT FOUND THAT 4 OF THE RETURN SPRINGS WERE GONE CLEANING AND PREP TO PUT BACK TOGETHER NEED SOME FEED BACK ON PLATES THANKS
Post by Lavoy » Tue Aug 05, 2014 3:55 pm
I am getting to not be a fan of the metallic plates, they are much more aggressive, harder on drivetrain, and harder on brake bands if adjusted to factory spec. If I do them myself, I adjust out of spec and run much less brake to get as little face pressure as I can on the discs. The pros are they won't swell, and should be somewhat less affected by oil, but there shouldn't be oil in there anyway.
FL450B
PROS AND CONS
Post by FL450B » Tue Aug 05, 2014 4:31 pm
THANKS I HAVE LEFT YOU A VOICE MESSAGE NEED TO BUY CLUTCH PARTS GIVE ME A CALL THANKS CARY
Post by Lavoy » Wed Aug 06, 2014 9:43 am
Got your message.
whiteclipse16
Post by whiteclipse16 » Tue Aug 12, 2014 6:43 am
Just a thought, is the metallic plates an option on the older dozers (440, 420, etc.)?
Ben
Post by Lavoy » Tue Aug 12, 2014 8:22 am
Not from Deere, but aftermarket.
Users browsing this forum: No registered users and 219 guests
