450 reverser oil
firetech
450 reverser oil
Post by firetech » Wed Jul 30, 2014 7:49 pm
hello can anyone tell me how to check reverser oil level? Is there a dipstick or plug? Filler hole? I lost a line to the reverser and finally managed to replace it and boy what a job it was. So now pretty sure it must be low or empty. Help!!!!!!!!!
70's john deere 450 crawler loader
Post by jtrichard » Wed Jul 30, 2014 11:07 pm
dip stick/fill hole is just ahead of where the steering levers rest ....right between your feet .... on the top of the trans
firetech
Post by firetech » Fri Aug 01, 2014 6:54 am
Well I guess I'm not that lucky. I found two rubber plugs approx 2.5" in dia and one hole approx 1/2" dia. No dip stick. Maybe I am missing mine. I removed the floor plates and checked all over. The hole is deep and I figure it is the dip hole so can anyone measure their dipstick from top of plug to fill line and maybe I can make a stick to measure. If anyone can post a pic of the stick in place that would help immensely. Can the stick be seen with the floor plates in place? Can I buy a new dip stick from somewhere?
Post by jtrichard » Fri Aug 01, 2014 10:00 am
should be a (about) 1"pipe nipple sticking up out of the trans cover maybe 3" with a screw cap that has the stick on it
jthornton
Post by jthornton » Fri Aug 01, 2014 11:01 am
Is a 450 similar to a 350?
That is my dipstick location the arrow points to the transmission dipstick and the reverser is clearly visible next to that U bracket on the floor plate.
JT
jsal
Post by jsal » Fri Aug 01, 2014 12:54 pm
My 450C HLR trans dipstick is under the seat not like the 350 under the air cleaner the one by the pto lever is the transmission
JIM
jthornton
Post by jthornton » Fri Aug 01, 2014 1:07 pm
Isn't the C model different for straight model for a lot of things?
JT
firetech
Post by firetech » Fri Aug 01, 2014 3:24 pm
thanks for the pics. I definitely don't have a dip stick like that. And if it is suppose to be like that then mine is missing. my transmission dip is also under the seat and not exposed to the foot floor plate area. Is your machine a 350 or 450.
jthornton
Post by jthornton » Fri Aug 01, 2014 3:45 pm
Mine is a 350, I didn't know if they were similar enough to be of any help.
JT
Post by Tigerhaze » Fri Aug 01, 2014 4:27 pm
Firetech do you know which submodel you have (straight 450, 450B, 450C)?
FYI, the online parts diagrams for the 450 submodels always show it being on the top of the HLR towards the front (i.e. the first (large) cover on the top). I'm guessing what differs between submodels is how the seat base arranged relative to the large top cover on the HLR. It does show it as a stickup tube with dipstick which would be consistent with the photo posted, Jrichard's description, and the tube/dipstick on my HLR for my 2010.
If you want to look for yourself at the parts diagram go to this link and search for "450" in the model search at top left, then go to the "922- 450 Crawler Tractor" link in the search results, then Sectional Index 35, Index 7:
Post by Tigerhaze » Fri Aug 01, 2014 4:34 pm
Double Post
firetech
Post by firetech » Sun Aug 03, 2014 8:22 pm
thanks for the posts. I don't know what sub model I have. All I'd s are missing. I do know its a 450 from all the previous owners receipts from service but that's it. I havent had time to check the other website but i will and thanks again. But really if anyone has a mid 70's 450 if you could measure the dip stick I will jerry rig a stick so I can measure levels till I can find a real one.
firetech
Post by firetech » Wed Oct 26, 2016 2:57 pm
Mine does have the "HLR" gear selector. Does that help identify my machine model?
Post by jtrichard » Wed Oct 26, 2016 4:57 pm
ALL 450s have HLR
Scottyb
Post by Scottyb » Thu Oct 27, 2016 8:19 pm
Under the seat cushion. Left side just behind your left heel. Big round head than needs to be turned out as it has threads under the cap. One dipstick for reverser and transmission.
backhoe attachment.
Users browsing this forum: No registered users and 251 guests
