Serial # help
Dan_in_AK
Serial # help
Post by Dan_in_AK » Thu Jul 03, 2014 2:35 pm
I have what I believe is a 450B 6-way blade. Everything points to it being a 450B, Non turbo, dry clutches, etc. It was re painted at some point, so there are no original markings.
I found the serial number where the manual said I would, but it is one digit short, and starts with a zero. I looked under the JD crawlers serial# info, and found nothing starting with zero. Kinda confused. Need to get the number right for ordering parts.
Anyone know whats going on?
Post by Stan Disbrow » Thu Jul 03, 2014 3:11 pm
What are the rest of the digits? The later below 100k serials started with a zero. You know, when someone realized they would be using a leading one before long....
Dan_in_AK
Post by Dan_in_AK » Thu Jul 03, 2014 5:33 pm
The entire serial number is T5F3M (space) 074233T
The parts guy said that I was missing a digit. I looked at the serial # info on this site, and nothing under the 450B starts with 0.
Post by Lavoy » Thu Jul 03, 2014 7:57 pm
Looks like 68 model straight 450 to me.
Post by Stan Disbrow » Thu Jul 03, 2014 8:27 pm
This is what I thought. When they got up somewhere around 70,000 they added a leading zero because they knew a leading one was on the horizon. But, that leading zero never showed up in the lists.
Just drop the zero and you will be at the correct serial number. :)
Dan_in_AK
Post by Dan_in_AK » Fri Jul 04, 2014 12:43 am
Lavoy wrote:Looks like 68 model straight 450 to me.
So what are the major differences between the 450 and 450B? The technical manual I got is for the B model, I was told it was a B when I bought it....... :?
Post by Lavoy » Fri Jul 04, 2014 8:43 am
From a service manual standpoint I don't think that much, parts would be the main issue I would think.
Dan_in_AK
Post by Dan_in_AK » Fri Jul 04, 2014 10:39 am
Is there a complete serial num database somewhere I can look through? I need to be sure I'm ordering the right parts.
Thanks, and Happy Independence Day!!
Post by Stan Disbrow » Fri Jul 04, 2014 10:47 am
There is a list of serial numbers by year in the FAQ forum:
http://www.jdcrawlers.com/messageboard/ ... php?t=2415
For knowing exactly which parts change by serial number, one needs the Deere parts manual.
Users browsing this forum: No registered users and 292 guests
