Jd 1010 blade
Jd 1010 blade
Hello everyone. I just wondered what model my dozer blade is. It is on a 1010 and it is a 6 way blade but is mechanical tilt and angle. Power up and down. Also the blade attaches on the outside of the tracks. Thanks in advanced.
This is a list of the John Deere blades as I far as I have been able to compile them. I will try to find a better way to display the data since I do not know how to embed a table or enter tabs on the website. The first "column" is the blade model number. The second is the crawler it came on. The third is the year it was produced. The fourth is whether inside or outside mount. The fifth is the mechanical or hydraulic functions and notes about Parts Manual availability. Gil
MC100 1949-1954 outside mount mechanical lift
MC60 MC & 40 1950-1954 inside mount
61 40 1954 inside mount mechanical lift and angle
62 420 1957-1960 inside mount hydraulic lift, mechanical angle
63 440 1958-1960 inside mount hydraulic lift, mechanical angle
64 440 1958-1960 inside mount hydraulic lift , hydraulic angle, hydraulic tilt
602 440 ? - 1960 outside mount hydraulic lift, mechanical angle pdf parts manual not available
76 1010 1961 inside mount hydraulic lift, manual angle
610 1010 1960-1964 inside mount hydraulic lift, mechanical angle
612 1010 1960-1964 inside mount hydraulic lift, hydraulic angle, hydraulic tilt
624 1010 1960-1962 outside mount hydraulic lift, mechanical angle
616 1010 1962-1964 outside mount hydraulic lift, mechanical angle
620 2010? 1960-1964 inside mount hydraulic lift?, mechanical angle? - like 610 pdf parts manual not avail
622 2010 1962-1964 inside mount hydraulic lift, hydraulic angle, hydraulic tilt
625 2010 1962 outside mount hydraulic lift, mechanical angle
626 2010 1962-1964 outside mount hydraulic lift, mechanical angle
A couple additions.
First blade listed is an MC1000 tool carrier which is actually a tool carrier onto which you mount the MC100 bulldozer attachment among many others.
Next was the #1000 tool carrier, 3 roller 40
#1100 tool carrier, 4 and 5 roller 40
