Steering clutch
1010c
Steering clutch
Post by 1010c » Wed May 28, 2014 9:27 pm
In my 1010c dozer the right clutch works well most of the time but some times it makes a bad grinding sound when i pull the lever and it boggs the engine right down and track looses power abruptly but if i keep travelling straight then try it again it works well any ideas?
Post by Lavoy » Thu May 29, 2014 8:34 am
Something is wrong, I would quit using the machine til I figure out what the problem is. Might be as simple as brake band worn out, or could be a bad bearing. Either way, it will cost more to repair if additional damage is done by continuing to run it.
wizner85
Post by wizner85 » Thu May 29, 2014 10:44 am
Sounds like the pinion bearing(s) are bad. Had that happen before. You pull back and you hear a grinding noise. (Grinding noise was the clutch disk wearing on the final drive casing. Since there was no bearing left, the steering clutch pack/ pinions shaft could travel in and out as it wanted to.
And it works once in a while too since sometimes you get the pinion shaft centered correctly and a piece of the broken bearing wedged just right in the race, and it works for 10 seconds..
When you tear the final apart, if there is a lot of fine grey powder, then your clutch pack was wearing on the final drive housing, and bearings are probably toast.
Good luck.
440 ICD 64 blade & 8a gear attic winch
440 ICD 831 loader with scarifier and weights
420 62 blade 3pt
Looking for 24 scarifier and 440 log arch
1010c
Steering clutch
Post by 1010c » Thu May 29, 2014 11:12 am
I hope it is not that i would say it works 60% of the time. How much work is it to take that apart and to take the steering clutxhes apart. Also Is there any special tools needed?
Post by Stan Disbrow » Thu May 29, 2014 11:23 am
It is quite a bit of work. Firstly, you have to split the track and drop it. Then you have to hoist the entire final drive assy off. Neither of which is light.
After that, it is not so bad. You do need the clutch pack setting tool at the very least.
While you are in there, replace everything. No skimping due to cost. Trust me on that one....
Also, might as well plan on doing the other side as well. Get it all out of the way at one time. Trust me on this as well. If you don't do both sides, it won't be long before you wish you had....
Post by jtrichard » Thu May 29, 2014 4:44 pm
if you read his other post the PO dumped DIESEL in the clutch housing to freeup the rusted clutch pack :o :o :o
1010c
Steering clutch
Post by 1010c » Thu May 29, 2014 6:32 pm
So for sure it was not a smart thing for the PO to dump diesel down. So what does everyone else do to free up the clutches ?
NEpilot
Post by NEpilot » Thu May 29, 2014 8:33 pm
A little TCE (trichloroethylene) will make the diesel go away.
John Deere 440IC
Re: Steering clutch
Post by jtrichard » Thu May 29, 2014 9:52 pm
1010c wrote:So for sure it was not a smart thing for the PO to dump diesel down. So what does everyone else do to free up the clutches ?
use the machine with the lever blocked back and If they wont break loose tear it apart :o :o :?
gregjo1948
Post by gregjo1948 » Fri May 30, 2014 4:22 am
I have done this job in less than four hours. (1 side) It wasn't my 1st time and I was familiar with the procceedure. I also had the parts I needed on hand. gregjo1948
1010c
Steering Clutch
Post by 1010c » Fri May 30, 2014 5:31 am
Okay thanks everbody.
Post by Stan Disbrow » Fri May 30, 2014 6:28 am
Yes, I have done both sides in one day. As long as everything behaves as it should. One stuck item, though.....
