440 ICD Blacck smoke
Captainjoe
Post by Captainjoe » Fri May 09, 2014 3:27 pm
Starting to get a lot of black smoke when running my crawler.Just noticed the today. So i quit early.
Doesn't seem to be burning any oil?
Going to switch from Rotella 30 weight to Rotella 40 weight?
Or would it be better to use chevron delo 100 40W
It's better to seek forgivness than to ask for permission...
Post by jtrichard » Fri May 09, 2014 4:44 pm
black smoke is fuel ....blue smoke would be oil .....53 SERIES DETROIT'S CALL FOR STRAIGHT WEIGHT 40
Captainjoe
Post by Captainjoe » Fri May 09, 2014 5:00 pm
started smoking more when I put in a diesel fuel additive as I double dosed it.
Its definitely black...
Injectors? maybe glow plugs?
No noticable drop in power just a lot of smoke... And she didn't hardly smoke at all before, under full power.
Book says 30 weight but your the second person that said to go with 40 weight...
Thanks, Joe
Post by Lavoy » Fri May 09, 2014 5:54 pm
Either 30 or 40 wt, I would lean towards 40 wt, but ONLY Delo 100 or equivalent, and there are not a lot of equivalents out there.
Captainjoe
Post by Captainjoe » Fri May 09, 2014 5:59 pm
so where do you buy this delo stuff?
Post by jtrichard » Fri May 09, 2014 6:32 pm
there are no glow plugs in Detroits .... Detroit diesel says 40 wt ONLY in 53 series engines
Post by Lavoy » Fri May 09, 2014 7:31 pm
You will have to go to Chevron oil jobber, not real likely to find it anywhere else. I finally found it at a large distributor about 40 miles from me.
Post by jtrichard » Fri May 09, 2014 8:10 pm
looks like OREILLYS has it $13 a gallon or should be able to get it http://www.oreillyauto.com/site/c/detai ... yword=delo
whiteclipse16
Post by whiteclipse16 » Sat May 10, 2014 9:54 am
It is tough to find.
Sounds like the fuel additive is breaking down some carbon buildup and has possibly clogged the injectors somewhat causing a poor fuel spray, thus making it not fully burn the fuel in the chamber.
Ben
Captainjoe
Post by Captainjoe » Sat May 10, 2014 11:09 am
lavoy,jtrichard,
Got two gallons of delo 100 40 on the way. Oreillys had in warehouse an is shipping to Parkersburg store(30 miles away) will be there at 4:30
WaaaHo! and i just picked up a Wix 51100 oil filter this morning...
Whiteclipse16,
Was smoking black before I added additive...
Now its really smoking...lol
Hoping it work through it as it will have a couple days to sit.
Thanks Guys.
How hard is it to clean / test / replace an injector(s)
Post by Lavoy » Sat May 10, 2014 12:59 pm
Pretty easy to replace on a Detroit, difficult to clean or test unless you have injection testing equipment. Rebuilts are in the $100 range exchange from Detroit.
Users browsing this forum: No registered users and 294 guests
