Wanted: 440icd single hydraulic valve parts
whiteclipse16
Post by whiteclipse16 » Sun Apr 20, 2014 5:51 am
Lavoy or anyone else.
I tore my control valve apart yesterday to fix the seal that was leaking and found the relief spring in about 4 pieces. Jdparts says it's not available.
Does anyone have a new spring? Lavoy would you happen to have a seal rebuild kit? Most of the seals i can get thru jd but thought a good kit would be nice.
Ben
Post by Lavoy » Sun Apr 20, 2014 5:27 pm
No kits I know of, sorry. Send me the part number of the spring and I will do some digging.
Post by jtrichard » Sun Apr 20, 2014 5:46 pm
If Lavoy cant find the right spring try McMaster http://www.mcmaster.com/#compression-springs/=rmhwut you should be able to get very close
whiteclipse16
Post by whiteclipse16 » Mon Apr 21, 2014 6:16 am
Lavoy the number for the spring is: T 10660 T
Do you have any of the seals on hand?
O-Rings T 10638 T
Copper Washer T 10654 T
Ben
Post by Lavoy » Mon Apr 21, 2014 7:50 am
O-rings and washer are good numbers, but I don't have them on hand. Spring I struck out on so far, sorry.
whiteclipse16
Post by whiteclipse16 » Fri Apr 25, 2014 3:10 pm
Thanks Lavoy, I'll search around for a spring. I know a guy that has a ton of old equipment, I think he might have an equivalent.
Ben
whiteclipse16
Post by whiteclipse16 » Thu May 01, 2014 8:02 am
Well, the spring has so far been impossible to find. I was able to find one that was very similar in strength but pretty short, so I doubled them up. It should function normally.
The copper washer number was superceded by a new number from Deere and the new thing definitely isn't a copper washer.
All in all, the 2 o-rings were the only correct thing. I got it all back together last night, just have to get it back on the dozer. Hopefully it won't leak and I'll have some up and down pressure now.
How hard are the cylinder seals to come by?
Ben
Post by Lavoy » Thu May 01, 2014 9:11 am
I might have seals on hand, but normally not difficult at all.
