starter grinding
crgenther
starter grinding
Post by crgenther » Sat Mar 22, 2014 2:17 pm
The starter on my 440 doesn't always engage and it makes an awful grinding noise.
I pulled it and the ends of the teeth on the starter are showing wear. fortunately there is little damage to the gear on the fly wheel.
The starter looks fine. Is there anything I can do or is a rebuild in order.
Curt
DukeofDeere
Post by DukeofDeere » Sat Mar 22, 2014 2:52 pm
Assuming it has been converted to 12 volt....
Go back to 6V.
Duke
crgenther
Post by crgenther » Sat Mar 22, 2014 3:29 pm
It is a 6v system.
Howard Yoder
Post by Howard Yoder » Sat Mar 22, 2014 7:06 pm
Clean it up good and put a new benex on it check the bushing on the end to.
DukeofDeere
Post by DukeofDeere » Sat Mar 22, 2014 7:20 pm
The other possibility is the starter ring gear is on the flywheel backwards.
Duke
crgenther
Post by crgenther » Sat Mar 22, 2014 9:12 pm
It use to work fine. The grinding is a new development.
I cleaned it good and lubed the drive mechanism.
Grinding got worse.
It doesn't have a bendix, it seems that the rotation of the starter throws the drive gear out, and a light spring retracts it after starting.
Near as I can tell anyway.
shinnery
Post by shinnery » Sat Mar 22, 2014 10:31 pm
What you are describing IS a bendix mechanism just not a solenoid activated positive shift bendix.
DukeofDeere
Post by DukeofDeere » Sun Mar 23, 2014 5:31 am
Does it finally start or just grind?
Duke
crgenther
Post by crgenther » Sun Mar 23, 2014 9:58 am
If I jog the starter switch on and off it will engage after two or three times, and then it will start.
Post by Lavoy » Sun Mar 23, 2014 10:11 am
Rebuild the starter with a new bendix.
DukeofDeere
Post by DukeofDeere » Sun Mar 23, 2014 10:12 am
Howard Yoder wrote:Clean it up good and put a new benex on it check the bushing on the end to.
He has the plan.
Duke
crgenther
Post by crgenther » Sun Mar 23, 2014 12:42 pm
I believe you are both right. I pulled a starter out of another 440, and it works great.
I would like to rebuild the starter, are all the necessary parts available?
The starter I replaced it with turns over slower, could it be a 12V?
It looks identical to the other.
DukeofDeere
Post by DukeofDeere » Sun Mar 23, 2014 1:02 pm
No difference.
Most conversions are done with no change to the starter.
Weak starters often need one or more of the new brushes, bushings, bearings, and fields.
Parts are available from Deere or here locally at Ademas rebuilders.
Lavoy may have some as well.
Duke
Post by Lavoy » Sun Mar 23, 2014 2:06 pm
I stock drives, but not bushings and brushes, or have rebuilt starters available.
crgenther
Post by crgenther » Sun Mar 23, 2014 3:31 pm
What does the bendix look like. I don't see one in the parts breakdown?
Users browsing this forum: No registered users and 197 guests
