John Deere 1010 diesel block cracked journals
So i bought a pair of 1010's a crawler loader w/hoe and the other has a six way. Long story short, both blocks are cracked at the journals. Is this fixable? Or am I going to have to find two replacement blocks?
(1) 1010 Crawler Dozer / Six way blade
(1) 1010 Crawler Loader / Backhoe
- DukeofDeere
The one is cracked above the main bearing journals this has been welded by the/a previous owner. The other is cracked clear through the journal itself. However both are cracked on the opposite side from the oil passages. I was wondering if it was a good idea to try and run these blocks? Or try to find replacements? I have my doubts that good blocks are going to be an easy find.
- DukeofDeere
the blocks have froze and split you need to find good a block/blocks those cracks will let coolant flow from cooling jacket around the liners to the oil pan..... they can be found ..watch how many main bearings you have
Users browsing this forum: No registered users and 320 guests
