Post
by Stan Disbrow » Sat Feb 15, 2014 11:30 am
gregjo1948 wrote:Hey Stan--If you're adding a velocity stack, you might as well install racing slicks!
gregjo1948
I saw a 420c with the rubber blocks on the pads doing a tractor pull. Off one of the recent Yoo Toob links, I think. So, for a crawler I think those are slicks!
original possum
Post
by original possum » Sat Feb 15, 2014 3:15 pm
Lavoy is right again! Turns out the 40C was burned and rewired by my electrical engineer brother while I was away in the Army. He added the resistor to save the points, but when I changed the coil it had to go. And he used all red wire.
Post
by Stan Disbrow » Sat Feb 15, 2014 5:13 pm
Ah ha! All red wire is fine, if you use Brady wire marking tags on them all to figure out which go where....
As far as electrical engineering goes, they skipped Ignition Systems 101 when I was learning it. I got my schooling in that field way earlier.
Post
by Paul Buhler » Sat Feb 15, 2014 5:34 pm
Me too. -- "Hold that plug near the hole while I crank the engine over. Let's see if there's any spark"; no rag, no glove, no joy.
gregjo1948
Post
by gregjo1948 » Mon Feb 17, 2014 6:28 am
Paul-- There might be a little humor in the plug holding, if you're not the holder.
gregjo1948
Users browsing this forum: No registered users and 238 guests
