whatchamacallit type electrical connector
- lurch85
almost done redoing the finals and a few other small things before i head for the swamp with my new steering clutches and brakes. while removing sticks from the belly pan, found I broke off the wires going to the neutral transmission switch broken off. Without getting a new wiring harness from Deere... just hoping to put a new end on each wire. I can't figure out what to call that type connector. It slides on from the side (same type of connector that the starter switch on mine has). I've seen them before... what do I call it? (I could modify a spade connector, but would rather use something made for it)
Help?
Help?
John Deere 420C, John Deere 350 straight with Gafner loader, John Deere 4020
whatchamacallit
I,ve had trouble finding these before, I think its a piggyback can be looked up on Mc Master-carr Web site
- lurch85
here is a picture of a similar style connection (male side) hard to find one that shows what I want to show.
http://www.ebay.com/itm/John-Deere-Igni ... 0729658015
- lurch85
found it. Talked to a guy dealing with tractor wiring harnesses, and he said its the same as the connector for mid 70s GM air conditioning pumps.
here's what it looks like.
http://www.overridemotorsports.com/ACDelco%20PT179
- cowboy4996
now you have to find where that switch has been bypassed .. i assume that you have been starting it with the key/switch? if so then some where they have ran a jumper wire from the switch to the starter
- lurch85
tried McMaster by the way.. (one of my favorite websites.. besides this one of course
) I just go on there and look and think to myself.. "That's pretty smart, never knew that existed!".. or "what would you need one of THOSE THAT BIG for?"
Users browsing this forum: No registered users and 211 guests
