2010 compression
jd gascap
2010 compression
Post by jd gascap » Sun Jan 19, 2014 5:10 pm
I read in the manual the minimum cylinder compression is 125lbs on the gas engine. I hope to look at a replacement one. I will do a check on each cyl before id buy. on a good used engine what should I expect to still be a usable one ? Thank you.
Post by Lavoy » Sun Jan 19, 2014 5:38 pm
Unless yours is junk, I would fix what I have before buying a used engine.
Users browsing this forum: No registered users and 165 guests
