2010 mistake
jd gascap
2010 mistake
Post by jd gascap » Wed Jan 15, 2014 9:04 pm
well a few months back I asked opinions about a 2010 crawler loader. I bought it and got stuck . #1 cylinder was rusted and oil pan is rusted through. I came across a wheeled 2010 with transmission troubles. he wants 1900 for the running tractor. I am not sure if the 3pt arms will fit other model tractors but if I part out the rest I could have a running engine when im done. what do you gentleman think? what is a running engine worth?
DukeofDeere
Post by DukeofDeere » Wed Jan 15, 2014 9:11 pm
Assuming it is a gas engine I would say $850-1250.
Just my opinion.
Duke
jd gascap
Post by jd gascap » Wed Jan 15, 2014 9:34 pm
yes it is a gas. all 2010 gas engines should interchange, shouldn't they? 2010 wheeled were made longer than the crawlers?
DukeofDeere
Post by DukeofDeere » Wed Jan 15, 2014 11:05 pm
Yes. They are the same.
Bolt right up.
Duke
Post by jtrichard » Thu Jan 16, 2014 12:45 am
if the oil pan is rusted through i assume it must be sheet metal? that engine must have been out of a wheel tractor ....as far as i know and what is in the parts book the crawlers all had cast iron pans
DukeofDeere
Post by DukeofDeere » Thu Jan 16, 2014 4:14 am
Bolt right up.
Duke
whiteclipse16
Post by whiteclipse16 » Thu Jan 16, 2014 7:20 am
jd gascap,
If you buy that 2010 gas and it has a good radiator I'd like to call dibs if you want to sell.
What is wrong with the trans?
My grandpa has 2- 2010 wheel, gas tractors. One of them has 5th and 6th gear gone, so I might be interested in your tranny too.
Ben
Post by Tigerhaze » Thu Jan 16, 2014 9:47 am
I know the bellhousing bolts right up between the 2010 wheel tractor engine and the crawler engines, but I thought there were some differences in engine arrangement and not just what JT pointed out? To be honest though I have never compared the parts manuals for the two gas engines side by side since my 2010s are diesel.
Post by jtrichard » Thu Jan 16, 2014 12:02 pm
water pump, crank pulley, fan and pulley, gen pulley, oil pan are all different on wheel ..... block, head, crank,liner, valve cover are the same.... exhaust manifold may be different
tlock0331
Post by tlock0331 » Sat Jan 18, 2014 2:21 am
If you end up with that parts tractor and the gas tank is good, i would sure be interested in it.
chet
Post by chet » Wed Jan 22, 2014 9:48 pm
Yes the exhaust manifold is different. Check out this earlier post, it might be helpful.
http://www.jdcrawlers.com/messageboard/ ... highlight=
Users browsing this forum: original possum and 31 guests
