thoughts on this 440?
Doesn't look too bad in the pics. The tracks do look to be adjust out pretty far.
Not sure how far you want to drive, but there's a gas one in central Ohio on ebay right now for about $2,999 OBO.
Might be able to get it for $2300.
Ben
Tracks are gone, adjuster is past the end of the track frame, so just assume pins and bushings at the least. Might need rollers as well, I would go and look at it in person if you are close enough to do so.
The definition of completely rebuilt means about 10,000 different things to different people, so I would find out EXACTLY what was done to the engine right down to under size on the crank, head work, injectors, etc.
Agree with Lavoy 100% .....the adjusters are way past "maximum adjustment" and you need as much info on "rebuild" as you can get
- DukeofDeere
If she steers well both ways $5500
$1200 is the value of the 3 point alone!
Duke
Duke
Also no reverser linkage so probably no reverser. Three point hitch is extra.
There's no track adjustment remaining.Undercarriage poor? Missing side cover for hydraulic control valves. (Not a big deal.) Doesn't appear to have a reverser. Manual tilt and angle on the blade. Sounds like a lot of work and money invested, but probably pins/bushings needed and possibly idlers and rollers. 3pt hitch and PTO are pluses. Might be worth the money if all it needs is pins/bushings. gregjo1948
Users browsing this forum: No registered users and 192 guests
