# 76 blade
# 76 blade
Will a # 76 blade fit on a 430C? of so, what else does it fit.
Brian
Brian
Thanks for the information.
Is this correct then...
MC60 is an inside arm with one hydraulic cylinder.
The # 61 was an inside arm single cylinder (4 way blade).
The # 62 was an inside arm dual cylinders (6 way blade).
Visually, how can I tell the 602 blade from the # 61 and # 62?
Also, what was the P/N of the blade that attaches to the MC1000 tool carrier.
Thanks.
Brian
Thanks.
Brian
Just thought I'd point out that the model 64 blade for the 440 was a power angle tilt blade. Pretty sweet if you happen to have one....
Mine is a Holt blade with outside arms, manual angle, and manual rotate. Would it be much like the 602?
I know that it was on the crawler from only a few years after manufacture, so it probably was built for the 420? Serial numbers are still visible. I think they are different for the blade vs the mount.
Gary.
Gary.
Users browsing this forum: No registered users and 265 guests
