new to me 350 straight
NWO Erik
Post by NWO Erik » Thu Oct 03, 2013 10:22 am
I have a recently acquired 350 straight gas dozer that does not have the reverser option......just reverse in the tranny.
IF I was able to find a similar vintage reverser from a donor tractor can it be installed in mine?
What is involved as far as additional parts or changes to what I have already. I understand that I will have to pull the engine, etc.....
Post by Lavoy » Thu Oct 03, 2013 10:28 am
As long as you have a complete reverser crawler to swap parts from you can do it. Whole center section gets replaced, clutch, clutch linkage, flywheel, isolator, and a host of other small things. Get a parts and service manual first and read through, you will see most of what has to be done.
Craig Williams
350 upgrade
Post by Craig Williams » Thu Oct 03, 2013 5:49 pm
about 6 years ago I did the same thing(also converted to diesel). If your desire is the challenge of a project then do it!! if you want a 350 with a direction reverser to use then buy one already running!! keep us posted
JWB Contracting
Non reverser 350's
Post by JWB Contracting » Thu Oct 03, 2013 6:57 pm
Anyone have any idea how many non-reverser 350's were made. My dad put one in the shed with an inside mount manual angle dozer and a gas engine as he thought it was rare. I think it's taking up space in the shed that I could be using.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Post by Lavoy » Thu Oct 03, 2013 7:04 pm
No production numbers that I know of.
Post by digitup2 » Sat Oct 05, 2013 8:32 am
Hay No Deere ever takes up space in a shed!!.Digitup.
