New guy with a 450b
New guy with a 450b
Hey guys. I have had my loader now for over a year. Very low hour machine. has the drott 4n1 and a backhoe. I bought the machine becuase we have 72 acers. lots of it is overgrown underbrush and smaller trees. I had been using the machine having no problems. It is really strong and I really have been pleased with it. I had a few hoses go out but no big deal. Until my hydraulic pump went out in the middle of the woods.I replaced it and filled my hydraulic tank back up and it all dumped out below the machine.
So now I have to pull the belly pan... out in the woods any tips? or anything I should know? THanks guys.
If you have a strong rops you might want use a winch and lift your loader bucket up in the air over the top of the rops and chain it up to get out of them woods.
I had a hole rubbed into the main rigid hydraulic line from the pump to the tank. I replaced it with flexible hose. It had many old welds in it from older repairs. Yours might have the same problem or even a crack.
backhoe attachment.
backhoe attachment.
correct mutli post
backhoe attachment.
backhoe attachment.
correct
backhoe attachment.
backhoe attachment.
I drove it in reverse to a better location. The whole property is woods, so no shop or anything. and taking it somewhere else to work on it is probably out of the question. I do have a mobile welder/generator and a compressor so Im sure I can get it done. I know one of my hard lines going down the loader arm rubbed a hole. It had a few spots that had been brazed previously. Im pretty sure the line coming out of the tank was tore up by a small tree... there was one wedged between the track and frame. I guess I should be ready to get dirty, I know there is probably 20 gallons of oil sitting on those pans
When you say the oil dumped out, was that immediately? Like as fast as you poured it in, it was running out? On my machine the both of the lines running from the pump have been replaces with hoses. I also had the added bonus of them using a galvanized street ell for one of the fittings.
If the oil is running out immediately then I would suspect the suction line going to the pump has been trashed. If it dumped the fluid after you started it then it would be the pressure line running from the pump to the valve bank. Either way you need to lower the belly pan to get at them. Not a job I look forward to..
450C Track Loader
291457T
291457T
JWB Contracting
Suction line
My guess is that your suction line came loose from the hydraulic tank. Pull your seat cushion and take a look.
The metal lines are connected by rubber hose and hose clamps.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
- Paul Buhler
Here's hoping Jason's right. If he is, then this might be a good time to elevate the crawler, drop the pan(s) and look at the steel line situation. Loose clamps and worn tubes are common and they never fail at a convenient time. Fixing them on your schedule rather than having a "must do" saves costs and frustration.My guess is that your suction line came loose from the hydraulic tank. Pull your seat cushion and take a look.
Nice looking machine.
Good luck. Paul
I pulled the seat off and I see the line you are talking about, Im sure it is on that line somewhere. the hose was still tight on the metal line though. I did have a limb wedge itself up in there, so Im guessing it tore the rubber somewhere down the line. Time to drop the pans, something I have been dreading.
- Paul Buhler
Back it up on 4 blocks of firewood to get clearance underneath for your body. Use supported bottle jacks for pan support and start loosening at one end working towards the other. In your case front to rear so you don't have to deal with the bucket. The pans are usually sprung, but the oily sludge in them often keeps the bolts loose so they remove somewhat more easily. The challenge comes putting it back on
when everything else is fixed. Lining things up and dealing with the few bolts/welded-in nuts that are stripped takes patience and care not to get something pinched. Good luck. At least you have a flat place to work.
