79 JD 450c track tensioner adjustment?
450cgreenhorn
Post by 450cgreenhorn » Mon Aug 26, 2013 3:48 pm
How do you adjust tracks on this machine? also I lost right steering control and believe linkage came apart under the seat/gas tank area how do I access linkage area to check? Everythings looks right and together all the way back to the fuel tank....tips, tricks, Pics????
DrLoch
Post by DrLoch » Tue Aug 27, 2013 8:43 am
Do you have any of the manuals yet?
With mine the seat bottom removes so I can get to the steering linkage and check the transmission oil level.
450C Track Loader
291457T
450cgreenhorn
Post by 450cgreenhorn » Tue Aug 27, 2013 11:57 am
no manuals yet. I know....get one right
Sabaro
Post by Sabaro » Wed Aug 28, 2013 10:19 pm
Hey there 450cgreenhorn, have you looked at the linkage that connects to the steering valve under the seat cushion? Did it stop turning to the right all of a sudden? Our 1977 450c stopped turning to the right also. when I opened the left steering housing inspection plug I got oil coming out and I can hear oil spraying. I think I have a hole in the pressure hose that delivers oil from the steering valve to the clutch pack. I only have this symptom in the left steering housing. The right is good. I will have to take the battery box, fuel tank, seat frame and hydraulic tank off to get access to the steering housing top covers. I know I don't have to take the hydraulic tank off for the left side, but I think I'm going to inspect the right hose anyway. What year is your 450c. My Technical manual number is TM1102. Check your year and model before ordering. I paid like $99 for a downloadable copy from johndeere.com.
450cgreenhorn
Post by 450cgreenhorn » Sat Aug 31, 2013 1:34 pm
thanks for the advice. yes it was all of a sudden. just no right stick control. I think its a 79 450c. is it hard to change the hose?
ib4hoyt
Post by ib4hoyt » Sun Sep 15, 2013 11:14 pm
you adjust the tracks by pumping grease in the fitting on the arm right behind the front idler
450cgreenhorn
Post by 450cgreenhorn » Wed Sep 18, 2013 11:19 am
thanks for the info ib4hoyt...also I just ordered a manual on ebay. should be here in a week....then i wont sound like a tard. lol
450cgreenhorn
450c greaser
Post by 450cgreenhorn » Fri Oct 11, 2013 10:56 am
well guys, I bought a manual, adjusted the tracks and popped the seat up and off to check out steering linkage(s)....well simple fix, $2 roll pin broke in the right steering brake pivot linkage, little bit of a pain to get to but we got'er. thanks for the guidance....
Users browsing this forum: No registered users and 187 guests
