350 B engine removal
bocephusfan1
Post by bocephusfan1 » Wed Aug 21, 2013 9:04 am
Anyone know about the bottom bolts on these dozers. Can the engine be jacked up high enough to get the bolt in the bottom left hand side of the machine out.. frame rail is in the way otherwise. Thanks for any help
JWB Contracting
Engine removal
Post by JWB Contracting » Wed Aug 21, 2013 6:45 pm
Use a series of long extensions from the front of the crawler to remove the lower mounting bolts.
The engine is bolted to the reverser and the reverser is directly mounted to the frame and crossmembers so jacking on anything will not be helpfull.
Good idea to check the reverser mounting bolts while you have the engine out. Bolted in sideways and from the bottom.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
bocephusfan1
Post by bocephusfan1 » Wed Aug 21, 2013 7:34 pm
I got it out today my problem is broken bolt on the isolator...
Users browsing this forum: No registered users and 218 guests
