5 year idle 440icd crawler-loader (want to start)
ozzie
Post by ozzie » Tue Aug 13, 2013 6:08 pm
has not been started 4-5 yrs. what are things I need to do before
attemting to start.
x---fuel tank,pump ,injectors,priming ?????
x---water,oil DONE
x---mag.???????????
x---starter ???? last time tried to start (4-5 yrs.ago) fire sparks flew from battery and
starter (suspect hung solenoid on starter ??)
x--- can hydr.pump be temp.shut off on this machine (ease in starting)
x--- other advice?????????????????/
Post by jtrichard » Tue Aug 13, 2013 7:22 pm
on 2 53 i would pull the rocker cover and make sure the rack is free ... and you can crack the inj lines and blead
JWB Contracting
Fuel rack
Post by JWB Contracting » Tue Aug 13, 2013 11:25 pm
I would also recommend removing the valve cover and make sure the fuel rack is free.
I would remove the intake bowl and have a rag ready to smother the intake in case the engine wants to run away in you. I don't think that 253's have a blower emergency shut off on them.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
whiteclipse16
Post by whiteclipse16 » Mon Aug 19, 2013 10:38 am
You don't need to crack the injector lines. The system will bleed itself.
Ben
Users browsing this forum: Google Adsense [Bot] and 242 guests
