New to this forum
New to this forum
Hope to learn a lot from you guys and also be a participant. Just acquired a 440 IC w 6way blade. Started learning from the get go, had some problems getting it loaded on my trailer designed for average sized tractors. At least no one got hurt.
John Deere 440 IC w/6way blade
14 other John Deere wheel tractors, Life is Good
That thing weighs about 10,000 to 11,000 pds and if your going up steel ramps you want to be level and not to steep even then it can be as exciting as ride at the amusement park. Would bolted on top of the ramps helps as long as it's not wet. I was in a bad spot once where the ground was unlevel and put a chain through the tract and hooked it to the front of the trailer and it worked really nice.
Users browsing this forum: Majestic-12 [Bot] and 25 guests
