JD450B undertray or ? hanging
- Contact:
Backing up my JD450B in dirt and it bogs.
I look underneath, and there is some component hanging, completely covered in dirt of course. Is it an under tray of some kind?
I have the technical manual, just hoping to have someone identify the likely component. Is there an under tray?
What is the best way to work on this? I don't know that I could fit under anyways, but the idea is definitely intimidating.
"It is incumbent on every generation to pay its own debts as it goes."
Thomas Jefferson
Thomas Jefferson
Hopefully you have not bent the belly pans. They are tough to straighten out. I had to park a crawler on one and use my skidsteer bucket to bend and beat it into shape. Went back on OK once I got the twist out of it.
backhoe attachment.
backhoe attachment.
- Contact:
railroad ties sound like a plan, presuming I can find some, I suspect they are heavy, but a car trailer could carry a couple, right? I just need to get them on it.....
I suspect it is the belly pan(s), that would make sense to me, Perhaps chain them to a tree and drive away from it....?
Thomas Jefferson
Thomas Jefferson
You'll need jacks to lift it, they are quite heavy. Just an FYI, I found mine loose, I never even hung it and I still needed a bottle jack just to raise it into position. My 450c uses 5/8 x 1 1/2" bolts to attach it to the frame.
If you have drove a large amount of dirt up between the pan and the frame / transmission you might want to consider a power washer to clean it out.
JD- 450C track loader
Serial #208336T
Serial #208336T
A gas engine power washer might draw water from a barrel or other container as long as you have it above the inlet of the washer.
- Contact:
Thanks, a good thought, as I do have the power washer, I would just need to get the water there. At one point I was considering bringing water up in the truck, maybe I have a reason to do so now. Any thoughts on a cheap secure safe way of carrying water in the back of a pickup truck?
Thank you all for the good ideas!
Thomas Jefferson
Thomas Jefferson
A good clean 55 gallon drum will work. If it is something you plan on doing on a regular basis, a new plastic tank with some plumbing and a valve would work great. Then if you want to put a gas engine pump on there for other uses, you are ready to go.
They make 250 gallon poly stock tanks that fit over the wheel wells in a pickup bed- may be a little more cost but will better distribute the load over the bed of you want more water than a 55 gallon drum and can be plumbed to standard fittings/pumps/etc.srshaw3 wrote:Any thoughts on a cheap secure safe way of carrying water in the back of a pickup truck?
- Contact:
As my well will be drilled shortly, I am looking for a cheap or no cost fix here, thank you thoughTigerhaze wrote:They make 250 gallon poly stock tanks that fit over the wheel wells in a pickup bed- may be a little more cost but will better distribute the load over the bed of you want more water than a 55 gallon drum and can be plumbed to standard fittings/pumps/etc.srshaw3 wrote:Any thoughts on a cheap secure safe way of carrying water in the back of a pickup truck?
Thomas Jefferson
Thomas Jefferson
i dont know about where you are at but here on the west coast home depots have ties.. a couple of 6x6s 8' long with a 2x6x8 or 2 depends how much room you want ( or like some of us NEED
) nailed on top will do also
Here you can go to the local ag stores ( the ones that sell liquid type fertilizer ) and pick up huge poly cubes. Mine is 4 feet cubed inside a metal cage and I paid 20 dollars for it. It even had a shut off valve on the bottom, I just had to buy a couple of reducers to get down from the 2" to a garden hose. You can move them empty by hand into your truck and fill them up.
Serial #208336T
Serial #208336T
- Contact:
This is exactly what I am hoping for, great, thanks.77 Ford wrote:Here you can go to the local ag stores ( the ones that sell liquid type fertilizer ) and pick up huge poly cubes. Mine is 4 feet cubed inside a metal cage and I paid 20 dollars for it. It even had a shut off valve on the bottom, I just had to buy a couple of reducers to get down from the 2" to a garden hose. You can move them empty by hand into your truck and fill them up.
Thomas Jefferson
Thomas Jefferson
Users browsing this forum: No registered users and 194 guests
