john deere 440 crawler loader ( joy stick control?)
ckutz1985
Post by ckutz1985 » Thu Jun 06, 2013 12:05 pm
I would like to replace my existing valve controls with a single joy stick . Is there a special one I need to get to do this? Or can I make any one work. I was looking at one out of northern tools one is called regenerating and one is not. What is the difference?
JD40c
Post by JD40c » Thu Jun 06, 2013 3:57 pm
Regenerative valving is used to make a cylinder work faster in one direction than another and isn't what you need for a loader.
1955 John Deere 40C 4-roller
Post by Lavoy » Fri Jun 07, 2013 8:19 am
YOu will need a valve that will handle about 15GPM, and adjustable pressure down to 1500PSI or less, open center.
ckutz1985
Post by ckutz1985 » Fri Jun 07, 2013 5:23 pm
Has anyone on here ever done this?
Labrador_tractor
Post by Labrador_tractor » Fri Jun 07, 2013 11:27 pm
Not a very hard conversion, I'm not familiar with the 440 controls so I can say how hard it would be to make a joystick configuration for your existing valve. but mounting a new valve is not hard, find a way to bolt it to the machine and hook up your hoses, done.
Here are two valve, first is higher GPM and cheaper, but take measurements and port locations into consideration for ease of mounting.
http://www.surpluscenter.com/item.asp?i ... =hydraulic
http://www.surpluscenter.com/item.asp?i ... =hydraulic[/url]
Wall:E
Post by Wall:E » Sat Jun 08, 2013 7:36 pm
In the last few weeks I finished replacing the entire hydraulic system on my 440; kind wish I would have known this was a viable option. Anyway, should be a fairly simple conversion with some minor fabrication work for the new mount.
Wally
username
Post by username » Tue Jul 09, 2013 7:41 pm
ckutz1985 wrote:Has anyone on here ever done this?
I think they offered a joystick control from the factory but it did not work out well as it constantly needed adjusted.
Post by Lavoy » Wed Jul 10, 2013 8:48 am
The joystick you are referring to was on the Pilot Touch crawlers, and was for the steering and reverser, not loader controls.
username
Post by username » Wed Jul 10, 2013 1:14 pm
Yes,that is what I was thinking about.I think I seen the article in Green magazine years ago.
pop pop
pilot touch
Post by pop pop » Thu Jul 11, 2013 12:19 am
hey guess what,,, mine had that but was changed back, i welded a big patch over the mounting hole and smoothed it out.
Users browsing this forum: No registered users and 161 guests
