motor tight
57jd420
motor tight
Post by 57jd420 » Sun May 26, 2013 7:13 am
had to replace the cam bushings in my 420's motor, get everything put back together and now it seems like the motor is turning tight. would not fire and after on a few cranks the starter was warm and smoking a little bit.
i'm totally lost on this one guys, any help would be great.
Home of the free because of the BRAVE!!!
1957 420 5 roller 5 speed
57jd420
Post by 57jd420 » Sun May 26, 2013 7:38 am
we couldnt turn it over at all by hand when trying to time the oil pump, discovered the governor was out issue. i'm pretty sure we got it back together correctly, as we could turn the motor over with the flywheel then.
57jd420
Post by 57jd420 » Sun May 26, 2013 9:27 am
also just had the starter rebuild about a month ago. i had the battery on the charger and it was turning slow so i put it up on boost and let it sit for a min or two. first pull of the starter turned close to normal speed for about 2 cranks then would barely spin the motor. the more i'm thinking about this could i have a starter issue?? or maybe its me hoping its a starter issue and not in the motor. thanks in advance for the help guys, starting to think this crawler is cursed!! :x
Post by Lavoy » Sun May 26, 2013 10:19 am
I would turn the engine by hand somehow to get a fell for how tight it is.
DukeofDeere
Post by DukeofDeere » Sun May 26, 2013 11:22 am
Sounds like a battery cable issue
Duke
57jd420
Post by 57jd420 » Sun May 26, 2013 12:45 pm
lavoy,
we were able to turn the motor by hand with the flywheel to time the oil pump and it did seem overly tight, that was after we took the governor off, and i believe we have it assembled correctly. you dont happen to have a pic of one correctly on the motor with the cover off do you? i will try and turn the motor by hand and see what i come up with.
Duke,
i was sort of thinking the same thing, but its brand new cables that are correct gauge.
57jd420
Post by 57jd420 » Sun May 26, 2013 3:55 pm
Lavoy, with the governor off it did not seem overly tight and we could turn the motor over by hand with the flywheel. sorry for the typo.
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Sun May 26, 2013 5:31 pm
I put new rod barrens in my 420 engine and did it in frame. I made the mistake of mixing up the rod caps when I torqued them down the engine wouldn't turn over by hand. after swapping the caps it was fine.
Something you might want to check?
nothing crawles like a deere
Post by Lavoy » Sun May 26, 2013 10:10 pm
Governor should not cause that, you have me stumped.
DukeofDeere
Post by DukeofDeere » Mon May 27, 2013 7:49 am
Cam bushings have an oil hole that needs to line up. This isn't an easy do it yourselfer job.after install did the new bushings get reamed to size? Just trying to help.
Any chance it has flooded while starting since the work was done? Cylinders may be washed from the gas. Often a hard start issue.
Duke
Captainjoe
Post by Captainjoe » Mon May 27, 2013 11:17 am
take spark plugs out and turn it over.
if it doesn't turn over easily... you've got bigger problems.
Plus it will eliminate any hydrolock problems.
I've always done this plus normally fog the cylinders with oil for lubrication.
It's better to seek forgivness than to ask for permission...
57jd420
Post by 57jd420 » Mon May 27, 2013 8:45 pm
the cam bushings are in correctly with the holes lined up with the oil slots that was actually the easy part. now somebody mentioned reaming the new bearings?? didnt know that was a requirement, if i'm remembering right it didnt mention anything about that in the manual. is there any easy way to do that?
also is there a trick to keep the cam followers in the block without turning it upside down?? really didnt want to pull the motor yet again.
Post by jtrichard » Mon May 27, 2013 9:37 pm
did you turn the cam by hand when it was installed? if so no need to ream bearings ... it is not clear what all you did to the engine?
Post by Lavoy » Tue May 28, 2013 7:52 am
Cam bushings should have been to size on that engine, never had a set that weren't.
Users browsing this forum: No registered users and 192 guests
