guage
Cuzz
Post by Cuzz » Sun Mar 03, 2013 5:15 pm
(1) set for 350 please... and thanks for all the effort.
Thanks,
Cuzz...
My wife says I never listen to her.... or something.
notmeu
Post by notmeu » Mon Apr 08, 2013 6:45 pm
Well finally after a lot of troubles the track wear gauges are finally completed. They were made out of Stainless Steel, laser cut and laser marked. The total price, with shipping included is 33.00 each, if you would like one of each gauge I will be able to discount that price. As you can see in the photos, the only difference between the 2 track wear gauges, if you are not familiar with these models, is the drive sprocket radius's. All of the other measurements are the same. The JD-267 gauge is to be used on the 40-4 roller, 420, 430, 440, 1010, 2010 before 42,000 serial numbers. The JD-266 gauge is for the 2010 after 42,001 and the 350. Since the gauges are made out of Stainless Steel and they have a glossy/smooth finish compared to aluminum, which is what the original gauges were made out of, they have a tendency to show very light scratches that do not affect the measurements. If you are interested please send me a Personal Message. Thanks!
JD-266 on the left JD-267 on the right
JD-266 gauge front and back
JD-267 gauge front and back
Howard Yoder
Post by Howard Yoder » Tue Apr 09, 2013 5:36 pm
I am interested in one of the 267 gauges What form of payment do you accept.
Thanks Howard
Post by Paul Buhler » Tue Apr 09, 2013 6:43 pm
Hi: I'm a visual learner. I can visualize how the gauge measures some track components, but I can't see how it's used for others. Did you find a manual on its use or did you explore its full range of uses? Could you post some more picture showing more of what it can do?
BTW, I'll PM you to buy a 420 gauge, just asking the other questions. Paul
notmeu
Post by notmeu » Tue Apr 09, 2013 6:57 pm
Paul Buhler wrote:Hi: I'm a visual learner. I can visualize how the gauge measures some track components, but I can't see how it's used for others. Did you find a manual on its use or did you explore its full range of uses? Could you post some more picture showing more of what it can do?
I will admit it took me a little bit to figure out how to use the gauge, but after a good 10 minutes I had it. To go over everything this track wear gauge measures or compares the new profiles to which is the grouser height, pin to pin wear, support idler wear, roller radius and wear between the flanges, front idler radius, minimum track sag, drive sprocket wear, and link wear. I'll have to take some photos and post them.
kedorland
Post by kedorland » Tue Apr 09, 2013 10:35 pm
Nice work.
Had been picturing the lazers effect on stainless.
Very nice craftman's ship.
Kevin
1975 450C. 1977 450CA loader, with winch and log arch. Is true..tracked equipment is addicting.
Post by Tigerhaze » Wed Apr 10, 2013 7:49 am
Notmeu, do you have a limited quantity of these gauges or are you making them on demand?
notmeu
Post by notmeu » Wed Apr 10, 2013 10:29 am
Tigerhaze wrote:Notmeu, do you have a limited quantity of these gauges or are you making them on demand?
I have about 35 of the JD-266 (350,etc)gauges left, and about 48 of the JD267 (2 cylinders) gauges left. So yes I do have somewhat of a limited quantity.
notmeu
Post by notmeu » Wed Apr 10, 2013 2:51 pm
Howard Yoder wrote:I am interested in one of the 267 gauges What form of payment do you accept.
Thanks Howard
Personal check or PayPal, but with PayPal I have to charge a little more because of the PayPal fees. Thanks
Scottyb
Post by Scottyb » Tue May 06, 2014 9:29 am
I would be interested in one for 350.
Roger440IC
Post by Roger440IC » Tue May 06, 2014 5:31 pm
I'd be interested in one for a 440 as well.
Thanks,
Roger
440-IC
420-U
notmeu
Post by notmeu » Wed May 07, 2014 10:24 am
Roger440IC wrote:I'd be interested in one for a 440 as well.
Thanks,
Roger
Thanks Roger, PM sent!
wfoidaho
Post by wfoidaho » Sun Jan 18, 2015 11:28 pm
Any chance you have a 350 guage left?
notmeu
Post by notmeu » Mon Jan 19, 2015 7:05 am
wfoidaho wrote:Any chance you have a 350 guage left?
Yes, I do, Although I'm starting to run low on my supply. PMessage was sent!
Les
What about the 450B?
Post by Les » Mon Aug 03, 2015 2:39 pm
Can any of these gauges be used with the 450B?
Thanks,
Les
Les
1971 450B Crawler Dozer
Users browsing this forum: Google Adsense [Bot] and 147 guests
