2010 Dozer (diesel) Parts
joe2kps
Post by joe2kps » Fri Mar 01, 2013 12:35 pm
Looking for a diesel priming pump for the 2010 dozer along with track chains and a track adjuster...Can anyone help me?
Thanks in advance!
Post by Lavoy » Fri Mar 01, 2013 1:41 pm
For the primer pump, look to an aircraft supply source, Aircraft Spruce is one I think I have dealt with.
Chains might be tough now, I know a while back I could get them, not sure now.
Adjuster should be no problem, but is dependant on serial number.
Post by Tigerhaze » Fri Mar 01, 2013 3:00 pm
joe2kps
Post by joe2kps » Mon Mar 04, 2013 7:46 am
Thank you guys so much. Where can I find the serial number?
Post by jtrichard » Mon Mar 04, 2013 12:37 pm
if its pre 42000 is on the right side of the engine block after 42000 it is on the bell housing just above and to the rear of the starter
Post by Tigerhaze » Mon Mar 04, 2013 12:48 pm
If pre-42,000, be sure that the data plate looks original. Oftentimes the serial number plate on the block is missing or one from an ag tractor (green instead of yellow letter highlights) due to an engine swap.
mnwoody
Post by mnwoody » Sun Mar 10, 2013 9:19 pm
I think I remember reading somewhere that the old deuce and a half military trucks used the same diesel primer as the 2010. Check the price at a salvage military vehicle parts yard.
Users browsing this forum: No registered users and 273 guests
