420 loader/crawler hydraulic question
panhead
Post by panhead » Tue Feb 19, 2013 12:42 pm
The top two cylinder's on my loader are leaking fluid.
They are the short one's, with the 2" diameter ram.
I took them apart to replace the seal's.
I can't get the cylinder to compress, is this due to the safety valve?
If so how do I get that valve out of there?
I have them off the dozer, so I could hook-em back up and suck the cylinder in, but is there another way? I could stand on these ram's, and they won't go in.
Post by Lavoy » Tue Feb 19, 2013 4:11 pm
No safety valve, something is stuck.
Gil
Post by Gil » Tue Feb 19, 2013 5:08 pm
Did you possibly put a cap on the lower hydraulic line to keep dirt out while you were working on it and then forget to remove the cap? Gil
panhead
420 hydraulic question
Post by panhead » Tue Feb 19, 2013 5:53 pm
Well, they are both sitting on my bench.
Nothing hooked to the dozer.
You'd sure think they would collapse.
Post by jtrichard » Tue Feb 19, 2013 5:58 pm
some times new cups can be very tight and hard to compress i have had to use a block of wood and a hammer to get them back in far enough to hook back up
gregjo1948
420 loader/crawler
Post by gregjo1948 » Wed Feb 20, 2013 6:51 am
I put some o-ring lube on the cup before installing. Occasionaly they still require some beating. gregjo1948
Users browsing this forum: No registered users and 223 guests
