sbarr
Post
by sbarr » Mon Sep 11, 2006 7:36 pm
The left side clutch on my 420 is starting to slip sometimes ,it will be working fine one minute then slipping the next.Sometimes steering right it won't drive it enough to turn.Is this a sign of worn discs or oily discs.
58 420c w 61 blade and 3pth and pto,57 420c w loader,48 D,48 M,Allis D-15 and a Super Duty to haul these!!!!
Howard Yoder
Post
by Howard Yoder » Mon Sep 11, 2006 8:11 pm
could be either check and make sure you have about an 1 1/2" play in your steering lever before your throw out bearing makes contact
sbarr
Post
by sbarr » Tue Sep 12, 2006 7:33 pm
Ya there is free play in the steering levers, both sides adjusted the same ,what is strange is it will slip only sometimes not always.
Howard Yoder
Post
by Howard Yoder » Wed Sep 13, 2006 7:18 pm
I think sometimes the clutches get oil soaked and then when they get heated up the oil comes to the surface and then it slips could also be a weak pressure plate
Howard Yoder
Post
by Howard Yoder » Wed Sep 13, 2006 7:20 pm
also make sure your brake petal is back all the way that can make them slip to.
sbarr
Post
by sbarr » Wed Sep 13, 2006 8:03 pm
Thanks for the info ,also when I take it apart is there a way to check the pressure plate spring pressure?
Users browsing this forum: Google Adsense [Bot] and 325 guests
