JD 450D Dozer 6way
Barnhardtsr
JD 450D Dozer 6way
Post by Barnhardtsr » Mon Jan 07, 2013 7:56 am
450D Track tensioner stuck wide open. Tried using block of wood between track and blade, no results. since it is wide open it will not take grease. Question: Can the tensioner be removed without removing the master pin in the track and replaced? Thanks.
88 450D
89 JD 70 Ex.
201 jd skid steer
Barnhardtsr
450D Tension stuck.
Post by Barnhardtsr » Sat Jan 26, 2013 4:52 pm
Thanks for your assistance. I was able to remove and replace using a little heat and lots of patience. :lol: :)
Users browsing this forum: No registered users and 353 guests
