JD56420C
Post
by JD56420C » Wed Feb 28, 2007 12:46 pm
Code: Select all
[img] http//www.jdcrawler.com/uploads/1956_420_crawler.jpg[img]
[/img]
Post
by wwattson » Wed Feb 28, 2007 1:55 pm
Let me help a bit with the picture.
- Site Admin
Post
by Lavoy » Wed Feb 28, 2007 3:27 pm
I can't see the lift mechanism well enough, it might be a 61, is definitely not a 62. A 61 does have one lift cylinder on the RH side, but the moldboard does not look quite right to be a 61. If you can, post a pic of the back side of the moldboard and the push arms.
JD56420C
Post
by JD56420C » Sat Mar 03, 2007 4:49 pm
Code: Select all
[img]http://www.jdcrawlers.com/uploads/420_blade.jpg[/img]
Lavoy, here are a few pics of the fram and blade I don't have any of the back yet but when I do I'll post them George
JD56420C
Post
by JD56420C » Sat Mar 03, 2007 5:00 pm
Code: Select all
[img]http://www.jdcrawlers.com/uploads/420_dozer_blade.jpg[/img] Well here is the blade I'm just getting used to posting pics sorry
JD56420C
Post
by JD56420C » Sat Mar 03, 2007 5:02 pm
I still can't get it right
Post
by wwattson » Sat Mar 03, 2007 5:17 pm
Looked right this time too George. I'll try it.
- Site Admin
Post
by Lavoy » Sat Mar 03, 2007 10:11 pm
That is an aftermaket blade, I can't help on the manufacturer. There might be a tag on it somewhere that will identify it, or maybe someone where will recognize it.
JD56420C
Post
by JD56420C » Sun Mar 04, 2007 9:06 am
Lavoy, it is beefy for an aftermarket blade it works well has a fram adapter to angle the blade for two different settings right or left. Compared to the 61 blade fram and blade this seems much stronger. Thanks for the info this site is always very helpful George
notmeu
Post
by notmeu » Mon Jan 14, 2013 5:43 pm
Your blade is a Greenville Rail Car Bull blade if you haven't found out yet.
notmeu on Mon Jan 28, 2013 4:21 pm, edited 1 time in total.
Eric.MacLeod
Post
by Eric.MacLeod » Mon Jan 14, 2013 8:04 pm
yup notmeu is right!! i have the same blade and they are made very well...
hydrogeo
Post
by hydrogeo » Sat Jan 26, 2013 9:32 am
I have the same blade as well. My machine came with an interchangeable root rake that looks too nice to be homeade. Pull two pins to swapthe out thethe blade goras the rake. It may have been another option.
notmeu
Post
by notmeu » Sat Jan 26, 2013 11:33 am
hydrogeo wrote:I have the same blade as well. My machine came with an interchangeable root rake that looks too nice to be homeade. Pull two pins to swapthe out thethe blade goras the rake. It may have been another option.
LOVE to see a photo of the root rake! I'm always up for more fabrication on my crawler.
Post
by Ray III » Mon Jan 28, 2013 3:33 pm
That looks like a nice machine, complete with fenders and sprocket covers.
I thought it was a Greenville Steel Car blade or is that another manufacturer?
I also would like pictures of the root rake. I am going to build one, but mine will hang off the blade. This way if I drive way out to a field, I can slip it off and use the blade after ripping everything up. It will also have a cage for pushing up brush piles.
notmeu
Post
by notmeu » Mon Jan 28, 2013 4:20 pm
Ray III wrote:That looks like a nice machine, complete with fenders and sprocket covers.
Yep your right it is a greenville steel car bull blade. I got corn-fused!
