Is it possible to adjust one of the clutch packs? The left clutch is weaker than the right. The left will pull but it just does not seem to have the bite that the right one does.
I have adjusted the levers per the manual and it did not change anything as far as the clutch bite. I do have better brakes as they needed adjusting.
I appears that someone has been in to the left side recently as the bolts are newer on the clutch pressure plate.
JD 440 ICD clutch pack
- JD440ICD2006
- JD440ICD2006
Could you not make up something to make me feel better?
So, I assume it will not hurt it to use it lightly, it will just finish off what ever needs to be repalced?
- JD440ICD2006
I know I made a big deal out of the oil issue but I believe the results were worth it. We all learned things, especially me, who knew nothing at all to begin with.
Users browsing this forum: No registered users and 206 guests
